I think I know part of the answer but after some advice.
The wife has ordered a new cx bike it comes with a Shimano Ultegra CS-6800 11-spd cassette, does this mean her old wheels (deore XT FH-M756-A) cannot be used with the 11 speed cassette, look like yes?
if this is the case, is there any cheap solution such as using an sram 11 speed cassette to use the old wheels, looks like no ?
Thridly and the reason of all this messing about Iron cross rims for the three peaks – good or bad idea? All the blogs seem to suggest high pressures are the way forwards but iron cross seem to be a bit focussed on low pressures, the original plan was to use either an old mavic rim or an aileron with landcruisers pumped up hard but may not be an option with the rear wheel now:cry:
Another alternative if the iron cross may not be up to it is get a Mavic Aksium One rear wheel and stick the casette and landcruiser.
Any thoughts gratefully received.
