In the interview bikeradar did with the head of RnD for SRAM, he stated they wont be bringing out cheaper versions of 1×11, so expect it to be an expensive must/must not have in 2013.
Makes sense, it’s a standalone groupset, but then again they said they wouldn’t fo Wi-fly (or whatever it’s called) accross all road groupsets, and shimano said there’d never be a DA compact.
Oddest thing is both of those developments trickled UP the ranges, XX1 went straight in at the top.
It could be a completely new Shimano groupset rather that a XTR replacement. Also SLX and XT were updated to 10sp mid cycle.
True, but they didn’t change anything, just the actuation ratio and clicks in the shifter. They kind of had to as OEM on MTB it’s common to spec XTR mechs, SLX cassetts, deore shifters, road bikes tend to be whole groupsets so having 10s ultegra and 9s 105 doesn’t make headaches for manufacturers.
