We have a deep, built in cupboard in our bedroom. It’s over a metre deep and sits over the stairs. Are suggestions on how best to use the space for storage. I had two thoughts:
1) add a few more shelves but pretty much keep the same system. The space at the front of the cupboard allows us to climb in to reach stuff at the top
2) replace the shelves with ones that a the same depth as the shelves. We could have two layers of storage I.e. Stuff we use regularly at the front. Stuff we use less often at the back.
Any other suggestions?
Edit: yes I know it’s a mess. We’re in the middle of redecorating
A couple of sets of those narrow space pull out kitchen shelves. You could then fill the cupboard and pull out each set of shelves separately to get at your stuff.
Re-space the shelves to get another one or two in
Make the shelves the full depth of the space
Follow your plan of separately storing less used items behind – maybe in boxes.
The door is a bi-fold type. It was in the ensuite – had to take it off while I did the flooring. Took a lot longer to get the stupid thing back on than it did to get it off.
I’m wondering if I could get two of the slidy out larder thingys side by side?
Or am I looking at a trip to Ikea……. (swallows nervously)
variant on the cupboard sliders idea… take all the existing shelves out and make a big square frame with castors on the bottom and panel on one side to replace the door so that all the shelves roll out and you can get to all sides of it (2 big handles on the panel front to help to bring it in and out)
you could use the bifold panels to make the front and get offcuts from wherever you can to make it for not too much
alternatively, get a load of runners and make deep shelves on sliders like open drawers
You could make some drawers & fit extending runners (telescopic drawer slides) to them that are secured inside the cupboard itself. Not sure how expensive it would end up, but something like these:
At the last place I worked, we used accuride slides that were pretty long and could take up to a 100% extension. They were rated for about 50kg, I think.
