Viewing 10 posts - 1 through 10 (of 10 total)
  • Sheffield singlespeed for road pootling
  • rob1984p
    Hopefully someone that lives in Sheffield or somewhere similarly lumpy can give me a simple answer on what singlespeed ratio I should be aiming for on my hack (700c drop bar). I have a 36 tooth ring I’d like to re-use.
    I previously used the bike fixed when I lived in Somerset but am not man enough to ride fixed up here.
    On my 9 speed 26″ luddite mtb that spends its weekends going up and down Wharncliffe I have a 1:1 as the easiest gear and can normally get up the climbs without resorting to this. and I appreciate that singlespeed is meant to be hard.
    Any advice gratefully received.
    rob
    36×15 (64″) should do you. I use 42×17 (64″) single speed around Sheffield.
    theonlywayisup
    I toyed with the idea, but soon discovered that any gear that was useful on the flat couldn’t get me straight up Upperthorpe and Springvale Road.
    Clearly I am not man enough to ride a singlespeed in Sheffield, so opted for a 5spd hub gear instead.
    rob1984p
    Cheers for the replies, I just ordered myself a 16 and will see how I get on, especially as I have to deal with the roads “theonlywayisup” mentions.
    jackthedog
    I ride 44-18 in Sheffield (700C).
    Bit spinny on the flat and occasionally brutal on the hills, but it’s versatile enough that I can get everywhere if I choose my route. Not always possible to go direct. For instance on the odd occasion I have to ride from Hillsborough to Crookes – there’s no way I can manage straight up the hill, so I generally go via Netherthorpe, Weston Park and Broomhill.
    I did however stomp up Blake Street last summer, just to prove a point. I’m just not exactly sure what that point was, and to whom I was supposedly making it. I think I was expecting ranks of beautiful women lining the road, swooning at my masculinity or something. Instead I just ended up falling into the Blake for a pint, which I drank alone and in silence, to no perceptible fanfare.
    sandwicheater
    jackthedog, your story has touched me like none other.
    sq225917
    Get a rear gear hub.
    thepodge
    I have used 22:16 on 700 fixed, you can ride up anything on that but you wont get there fast and 34:17 on 26″ which gets you there faster but means you have to walk. I too have detoured via netherthorp to get from the ‘bro to places otherwise I go blind with effort
    theonlywayisup
    I should have added that I was on a 26″ MTB* with 1.75″ slick tyres, so you’ll do better on 700c wheels.
    Good luck, and I’ll remember to say “hi” if I see you gurning up Upperthorpe or Springvale.
    * 26″ being the correct wheel size for a real MTB 😉
    rob1984p
    I’ll probably just grunt at you!
    You’re quite right about MTB wheel sizes, my 1×9 26″ P7 is a delight. This however is a 1970s Claud Butler Cresta tourer which is a superbly balance thing that looks nothing special so can happily be left locked to lampposts outside pubs and the like.
The topic ‘Sheffield singlespeed for road pootling’ is closed to new replies.
