- This topic has 38 replies, 16 voices, and was last updated 6 years ago by matt_outandabout.
Sheffield
molgripsFree Member
Looks like whilst there are some obvious trails in the hills nearby, I might be better off with a ‘gravel’ bike for some mixed riding?
Where should I look at for MTBing in the area?
matt_outandaboutFull MemberSheffield local riding is almost as rocky as the rest of The Peak.
OnzadogFree MemberWhich bit of Sheffield? Most of the mountain biking is straight outside the front door.
vincienupFree MemberDepends what you plan to ride. A gravel bike or cx will be great for commute, trans pennine trail etc and will cope with most of the Peak at lower speeds and more fear. If you’re after a one bike solution, then a good HT with a fork that is easy to service and doesn’t have short service intervals is my recommendation. FS would get expensive to run quite quickly if used as a daily ride around town – and would also be more of a scrote magnet for hanging on to.
jefflFull MemberI guess you’ve got Parkwood in the city but anything that’s not man made will be in the peaks, which will be rocky. Bit confused by the question TBH.
Though saying that I’ve got my London Road which I’ve taken across Curbar edge when linking some stuff up.
thepodgeFree MemberI’ve not touched my mountain bikes since I got my gravel bike.
Totally depends which bit of the city you’re at.
Takes me longer to get to Cannings / Houndkirk / Blacka than it does to get to Ladybower.
cpFull MemberThe city is pretty much surrounded by options which would allow you to use either/or mtb or cross bike in the same place. Eg. Wharncliffe – great for a cross bike on fire roads and smoother singletrack, also great on a slack mtb for tech trail fun. Or head out to lay cannings and beyond – doable on a cross bike, albeit the roman road and froggat edge is rather uncomfortable on a CX, whereas mtb can be fun.
Blakca moor would be very uncomfortable on a cx bike.
Are you coming for a visit or live here? What do you want by ‘mixed riding’?
molgripsFree MemberWhich bit of Sheffield?
I’ll be staying in the centre. It’s my next work posting.
The question is about where to ride, since I have looked at the map and whilst there appear to be some trails, it doens’t look like there are very many.
If there aren’t many, then I’d be better off with the gravel bike because I’ll end up doing lots of road… tell me what I am missing..?
The choices are rigid mtb or gravel really. Bouncy bike not so easy.
cpFull Memberit doens’t look like there are very many.
Abolsutely shedloads – but OS maps aren’t up to date with all the shared use paths/upgraded bridleways.
here’s a few straight from the city centre.
Just north of the centre – Parkwood Springs. short but fun MTB – good for ‘sessioning’ of an evening.
Bit further north – Wharncliffe and Grenoside. MTB or cross depending what you want to do, trails for both. Ride up from the centre through Beeley wood next to the river – OS maps show footpath but it’s a multi-use trail.
Rivelin/Stannington/Loxley – Ideal CX ground – put together several bits of bridleway and road for ‘mixed’ fun – with potential for one or two skethcy-on-a-cross-bike moments.
Lady Cannings – MTB ideal. Ride up offroad through Endcliffe Park from the top of Eccleshall road. Then you can head out to the roman road and froggat edge (another one that looks footpath on a map but is actually now a bridleway).
Blackmoor – nice way back into the city from Froggat/Lady Cannings. Defo MTB for fun rather than survival…
thepodgeFree MemberThere are quite a few options, I’m not going to list them on the internet as most are largely comprised of places you’re not supposed to ride.
If you want to ride in Sheffield city then you’ll be better off with the gravel bike, for example I recently rode mine from work to Stanage and back.
If you want to ride in the Sheffield area then you’ve got all of the Peak less than 30 minutes away.
You’ll find trails to suit whichever bike you bring.
cpFull Memberare largely comprised of places you’re not supposed to ride
there’s loads perfectly legit
vincienupFree MemberAlso note that there’s very easy access to the Peak from the city by bike without winching yourself up road climbs. Endcliffe park and Riv Valley are both good access points.
Surprised no one has floated the Vertabrate ‘Dark Peak’ guide yet. It’s a good starting point.
Plenty of groups, Ride Sheffield, Coggers etc on that FB…
DigbyFull Memberbut anything that’s not man made will be in the peaks
I think you will find that pretty much anything in the Peak District will also be ‘man made’.
If you like riding mainly rocky double-track then the Peak District is ideal for a CX bike. There are a small number of decent downhills where a mountain bike is required to get the most of it.
Sheffield and the immediate surrounding area has some amazing riding. What some of the tracks lack in length they make up for with ‘interest’!
This is very true – you can bring any bike and you will find something to enjoy, but a fair amount of ‘local knowledge’ is required to tie things together – but that is half the fun for some people.
From my perspective, I think the problem is it’s more a case of the attitude of the people riding the places “you’re not supposed to ride” rather than the actual legality per se.
The recent explosion in popularity of the Sheffield cycling scene in general and mountain biking in particular coupled with an unfortunate ‘sense of entitlement’ amongst some of its participants has not done much for PR … 🙁
sofaboy73Free MemberJust north of the centre – Parkwood Springs. short but fun MTB – good for ‘sessioning’ of an evening.
This – definitely bring your mountain bike. I’d say that Sheffield probably has some of the most accessible mountain biking in easy reach of the centre than many other cities of it’s size. I live 2.5 miles from the city centre, but can still ride to greno & wharncliffe in less than 30 minutes
molgripsFree MemberThanks folks this is good info.
This is the problem. I’m up for three weeks, maybe more if there’s an extension, and I don’t have time to gain ‘local knowledge’. I need to be able to get out a map and go riding quickly.
FunkyDuncFree MemberI’d say that Sheffield probably has some of the most accessible mountain biking in easy reach of the centre than many other cities of it’s size.
I used to live in Hillsbrough and thought the ride out to Wharncliffe/Greno was a pain. Proper peaks was certainly not rideable from the doorstep, and practically any route in the Peaks requires some road work.
So I would say gravel/cx bike.
However where I live now is a 30 second ride to off road, so I guess its all down to whats classed as quick 🙂
GHillFull MemberPlenty to keep you entertained with either option. If you fancy some gravel bike stuff then just give me a shout and I’d be happy to show you some routes.
antigeeFull Membernot sure on the complexity or rules but if based city centre then train to hathersage or hope is an option
I love my CX and there is some great mixed road stuff to be done but their is some unmissable mtb to do first – enjoyDigbyFull MemberI don’t have time to gain ‘local knowledge’
In which case … +1 for the Vertebrate Publishing ‘Dark Peak’ guide book
… I’ve lived in my part of Sheffield for nearly 30 yrs and I’m still discovering new bits! 🙂
sofaboy73Free MemberI used to live in Hillsbrough and thought the ride out to Wharncliffe/Greno was a pain. Proper peaks was certainly not rideable from the doorstep, and practically any route in the Peaks requires some road work.
that were I currently live and personally don’t see it as a pain as I have to do all of 5 minutes on main roads and then the rest of the route is off road / very quite roads or with a few hundred yards on jawbone before getting the wharncliffe
OP are you bringing a car? if so, deff bring your mountain bike. If you haven’t got time to plan / learn routes, give me a shout and i’ll show you around if your want (if you can ride at a middle aged man pace, if your young and super fit, you’re on your own!)
thepodgeFree MemberGHill – Plenty to keep you entertained with either option. If you fancy some gravel bike stuff then just give me a shout and I’d be happy to show you some routes.
Is this an offer open to us all? I’m enjoying my gravel bike a lot but wouldn’t mind stretching my legs outside the North West of the city.
sofaboy73 – that were I currently live and personally don’t see it as a pain as I have to do all of 5 minutes on main roads and then the rest of the route is off road / very quite roads or with a few hundred yards on jawbone before getting the wharncliffe
You could be on my street with a description like that.
OP, if you’re only here for 3 weeks then I’d go for mountain bike in the Peak or gravel bike round the city.
molgripsFree MemberThanks for the offers of guiding. Maybe we can have an STW ride? 🙂
I may bring a car, not sure yet. I don’t mind riding out to the hills from the city as long as it’s not madly busy.
I’m up during the week and back home at weekends. Probably Mon-Thurs atm.
sofaboy73Free MemberYou could be on my street with a description like that.
if you live next to the Wednesday ground, I probably am!
philtricklebankFull MemberPlenty of groups of mates go out most evenings of the week. We go every Wednesday night if you want to tag along. Often a location rideable from city centre, but lifts almost certainly available if not.
thisisnotaspoonFree MemberIf you want to ride in Sheffield city then you’ll be better off with the gravel bike,
for example I recently rode mine from work to Stanage and back.[b]if the potholes are still as bad as they used to be[/b]There can’t be many cities with more accessible MTB’ing? Ok so the first 3 miles might be on cycle paths, but that’s a decent price to pay for being able to do Stanage/Cannings/Blacka in a short evening ride!
DigbyFull MemberI certainly don’t want to ride around a city
Well make sure that your accomodation is on the ‘WestSide’ then*
*although areas like Dronfield & Eckington do have some good riding!
thisisnotaspoonFree MemberFrom the city center (Bramal lane roundabout) you pretty much just ride up Ecclesall road to the next roundabout, then into the woods which are a mix of cyclepath and cheeky diversions up into the trees. Up Potters Clough (steep gravel lane), and then you’re in the Peak District. By Sheffield standards it’s a flat ride too!
When coming back in via Dore you can do a diversion up through the rugby club to come back the same way.
sq225917Free Memberslack hardtail with a dropper is probably the best bet for taking in everything Sheffield has to offer.
DigbyFull Memberyou pretty much just ride up Ecclesall road to the next roundabout, then into the woods
“Former ‘Student’ perchance?” asked Paul Calf
sofaboy73Free MemberWell make sure that your accomodation is on the ‘WestSide’ then*
or north side for greno & wharncliffe (varying degrees of technical, short downhill runs rather than ‘rides’ per say) and easy access to peak via rivlen valley
DigbyFull Memberor north side for greno & wharncliffe (varying degrees of technical, short downhill runs rather than ‘rides’ per say) and easy access to peak via rivlen valley
All of which are within the ‘Western Hemisphere’ of the Greater Sheffield Metropolis I was referring to with ‘WestSide’! 😉
antigeeFull Memberride up Ecclesall road to the next roundabout, then into the woods which are a mix of cyclepath and cheeky diversions up into the trees. Up Potters Clough (steep gravel lane), and then you’re in the Peak District.
if staying in city centre then roundabout is at junction of Eccleshall rd and Brocco Bank, head into Endcliffe Park to start following Porter Brook then through Whitely Woods possibly signposted Forge Dam (5 years since lived in Sheffield) which becomes Porter Clough – after the park far from urban and a good way out of the city by bike
DigbyFull Memberif staying in city centre then roundabout is at junction of Eccleshall rd and Brocco Bank
I’d given up with TINAS’ post after his student spelling but at least he did get Ecclesall Road correct … 😉
jefflFull MemberIf you’re in Sheffield for three weeks bring the MTB and do some of the routes from the VP Dark Peak book.
ahwilesFree Membermr grips, send me an email (in profile), i’ll gladly show you around.
matt_outandaboutFull MemberI was mean to be in Sheffield next week, I had rides out to the Peak with mates lined up an everyfink. However the course I was on has been cancelled. 🙁
The topic ‘Sheffield’ is closed to new replies.
