planning on building a new shed in the next few months as a bike store/general workshop. it’ll be my 3rd shed i’ve built but the biggest, so i’ve drawn some rough plans up for a partitioned 6ft x 14ft layout as that’s all the space i have to play with. i want to have a solid concrete floor like in a garage or brick shed, and build the structure out of timber
has anyone on here built a shed to this sort of spec? i want the concrete floor for fixing ground anchors/tool boxes/heavy duty work bench down and be as durable as possible. previous shed’s i’ve built have all been raised wooden floors on timber bearers but i’ve only used them for storage. also i want to maintain as low an overall height as possible to not cut out too much light to our patio area/kitchen window – 2m pent roof is the thought for now. what i’m concerned about is what to do where the timber meets the concrete base – should i try to provide an overhang so any rainwater on the shed cladding doesn’t pool on the concrete base and seep underneath and rot the frame/pond inside? or should it sit on top and be sealed somehow? any other ideas/solutions/details? i will be putting a filter drain next to the shed as the garden falls towards it, so water from run off off the garden shouldn’t be a problem. all advice appreciated! cheers
