Base for my shitty metal shed:
30cm x 15cm deep hole into clay around perimeter
20cm deep excavation in middle
Fill perimeter with large rocks to level of middle excavation, top up the lot with 10mm of chips (I used hideous red chip that was covering the garden, other varieties are available, usually free).
Walk over it and pack it down, the head of a sledge hammer will do, leave it a few days and it will do it pretty much on its own.
Cover with anti weed sheet.
Coat with builders sand, just enough to level it.
Lay council slabs over the top.
Has been dry as a bone since I laid it, I do get dampness around the edges as it’s not a sealed shed but using them as the floor has given me no issues, the middle is always dry. The clay around it likes making puddles so the soakaway obviously works. When I come to putting a proper shed on it I’ll just plonk it on top of a sacrificial layer of timber with DPC on top to be sure but thats probably overkill.
That Tiger shed, lol. Look at how its put together and it doesn’t matter what you use as materials, a pry bar will have it apart in minutes! So called security sheds just make me laught, taking away the window means just about sod all if a thief can just pull it apart at a seam.
