As mark said,
A few ideas below too:-
1)Lay either 2×2 or 3×2 paving flags on a grit sand and cement mix.
2)Fit chicken wire inside around the perimiter and either ply over or use the 18mm chipborad flooring sheets B&Q etc.. do
3)Strenghten door up using 18mm Ply and fit a decent size but not attention attracting hasp and staple and Padlock
4)Cut out a section of floor, say 300mmx300mm, break through paving slab, dig out earth and fill with concrete level with shed floor ready to fit a ground anchor
5)Swap a couple of door screws for coach bolts
6)Use more screws and slighty lager sized than they reccommend throughout the construction.
7)Get a lock with built in alarm or fit shed alarm.
A little OTT maybe but from the outside it just looks like a standard shed, internally it is not.
Carl
