My 5 year old adores science, and together we play about with the usual kitchen science..
Vinegar and bicarb in various guises to fizz and pop..
Washing liquid in milk etc
I’ve got a few books on order, but would love to hear what experiments you remember from school, our do with your kids!
It would be cool if it was all easily accessible chemicals, but might hunt about online for other bits and bobs!
Non newtonian fluid….. Cornflower and a little water… Stir it slowly and it’s wet, fast and its hard (oo Er) can be poured onto a board and hit with a spoon/ladle/ mallet and won’t splash… Add a bit of food colour for added effect. Easy to clean up!
Ha Esme, that reminds me when I was a kid my Dad brought a flask of liquid nitrogen home (he was a physicist) and we dipped things in it and threw them against a wall to watch them shatter! Carrots, bananas and the hose pipe spring to mind!
If you do the candle in the upturned jar, just don’t tell them the water’s risen up because the flame used all the oxygen… very persistent wrong explanation!
Photocopied image (keep it simple)
Plain T-shirt
White spirit, water and washing up liquid, old bottle of some sort
Baking tray big enough to fit the photocopy in
Iron, ironing board, plastic sheet & old tea towels
White spirit and water in the bottle (can’t remember the ratio so try 1:1) and add a drop of washing up liquid. Put lid on and carefully shake to mix.
Put photocopy into tray and pour over mixture
Plastic sheet on ironing board to protect it and lay T-shirt on with side you want the image on facing up.
Remove wet photocopy from the tray and lay on the shirt
Place a tea towel over the photocopy and iron
Image should transfer from the photocopy to the T-shirt.
Bingo – DIY T-shirts using nothing more than stuff you find at home. Might also work for colour printing and laser printing but never tried that when I was a kid.
Get some cheap kitchen scales and get some varying weights between 1g and 500g.
Force them to weigh each weight a bazillion times, noting the results given in a lab book. Then force them to carry a statistical test to see if any of the scales differ significantly from one another. Then force them to write it all up and consider why variation in instrumentation is important, making sure they harvard reference. Tell them their pocket (grant) money is dependent on you receiving adequate results. Halfway through…. break 2 of the scales and force them to fix the scales as you cannot afford to buy anymore. Tell them to consider the effects of this on their experiment, also admonish them for not maintaining the cheap and nasty scales in the first place. Make them wear gloves, goggles and face masks into the play room to carry out their experiments. If they do not, note it down and bring it up in a performance review. After they have given you good results, tell them they are fired and will no longer be entitled to any pocket money other than what they are owed.
Actually a lot of cooking can be linked to science, particularly chemistry. We do a lot of biology when I joint meat, or fillet a fish. Some of the morphology in a chicken is great for explaining dinosaurs, and saving and using ligament from a deer makes superb bow.
On a less controversial note balancing a needle on water (surface tension) to show how a compass works.
You can make graphene in your kitchen using a couple of trivial methods. Trouble is, there’s no obvious endpoint for the experiment (AFAIK) that could engage children, you’d just be pointing at a load of black shite and calling it graphene.
Might be worth it for older kids, peeling it off with scotchtape to show how simple experiments can lead to a Nobel prize.
I had an interest in biology and anatomy when growing up. My mum was a theatre nurse…
Flash freezing water (spectacular… If you get it to work) Clouds in a bottle
Testing stuff with pH paper – my classes love this.
As mentioned before – non newtonian fluids are great.
Anatomy can be done with a whole fish/crab/lobster from the fishmonger.
Pepper sprinkled onto plate of water then touch the surface with a finger covered in washing up liquid.
Also, check out a guy on YouTube called the crazy Russian. He has got all the science based tricks you need to keep your lad entertained for months!
The methane bubbles / light in your hand one always gets them.
For the boys party I managed to get some 35% hydrogen peroxide and potassium iodate solution for a volcano experiment. Made a massive paper mash’ volcano. Doubled the volumes I was previously working with and covered the ceiling in the hall I was doing it in with foam. kids loved it.
Posted 9 years ago
Viewing 37 posts - 1 through 37 (of 37 total)
The topic ‘share your kitchen science experiments…!’ is closed to new replies.
