Hi folks, first post from a new Stooge (mkI) owner.
I’ve just finished setting up an Alfine 8 speed rear hub on mine after running it as a singlespeed for a few weeks as I couldn’t quite find a satisfying compromise gear ratio-wise between riding on flat roads and then trying to haul up the hills off road.
Anyway, a bit stuck getting the optimal set-up with the hub, the chain and the eccentric bottom bracket.
I cannot find an optimal chain tension at all. Just running through it with some old chain (I checked, barely 1/16th stretched) and I can either join the chain, with the BB set back at 9 o’clock at what I’d describe “angry banjo wire tightness”, or with an extra link and the BB at 3 o’clock, just a bit too slack to ensure it’s not going to pop off. There’s about 12-15mm of vertical movement then. With a new chain I’d probably be there as it’d be a couple of mm shorter, but the bottom bracket is forward and up of where I want it in that 3 o’clock position. Ideally somewhere in the 6 to 9 o’clock range would be great.
Given I wouldn’t mind a tiny bit higher gears- could I leave the chain as is and then buy a chain ring with, say, 1 or 3 more teeth for the front and that’d let me swing the BB down (to shorten the chainstay a touch) get it where I want and make my gears slightly taller?
Advice much appreciated.
