howdy partners 🙂
righty, new shifters new/new cables time!
so when assuming all my H L screws are fine (which im sure they are at present)
remove cables (easy enough)…..then which gears do i drop into to ensure the new cable will be the correct length? for both front and rear derailleur? also what about the barrel adjusters, do i just leave them as they are? or do i need to reset them to accomodate new cables? if so how?
setting up indexing – assuming everything goes on ok, the barrel adjuster then indexes the gears, what gear should i be in the start the adjustment process??
i have a rough idea i think, but some of the points above unsure on so would like some expert simple instructions pleaseeee 🙂
