Mx comps are easy, and as you say. You want a socket extension bar to jam down them though IIRC.
Think (from depths of memory) they’re just a spring in one leg as it is?
If you can’t soften them up that way, try dropping the oil levels a little (like 10ml to start). Increasing the air volume reduces how much they ramp up as they compress, so can make them more usable at lighter weight. They’ll likely be 7.5wt oil as standard too, you could try 5 for lighter damping too.
I have some X-fly 100mm 2001 – would you have charts for them please?
Maybe, I know I had some old charts before and probably didn’t delete them, I’ll try and remember to look…
