Anyone changed the oil in an inverted FIT damper?
Its a fox 36 Rc2 FIT Vanilla if it matters.
It seems you need a special “miximiser” syringe only available in america land to bleed the damper! cant see whats special about it or find anywhere to buy one..
http://service.foxracingshox.com/consumers/Content/Service/QuickTech/36FITRLCFullServProc.htm
I can do the rest of a fork service, and like to do things at home so thought I’d try and give it a go…
I also wanted to try some lighter weight oil in the damper, the damping range seems to stay in the lower end all the time so thought it might work well, anyone tried going down to a 7wt?
If I’m mad and should just send it off tell me! I suppose I could just have the damper serviced… but I do like to figure these things out for myself if I can…
