150mm Rock Shox Sektor RL Dual Position Coil Trail Suspension Forks.
Black dual position, as new forks, bought on a whim and now for sale, boxed. Genuine under 100 miles done (5-6 rides)and immaculate.
Steerer is 220mm long. Currently £350 on CRC, FOR SALE £275 with transferred shop warranty and courier next day delivery.
Blurb below
http://www.chainreactioncycles.com/Models.aspx?ModelID=71184
Offering a bevy of damper and spring options, including Motion Control, Sektor remains the clear choice for real-world trail bikes and real-world riders. When what’s around the bend remains to be seen, the Sektor’s stout 32mm upper tubes, Maxle Lite options and external rebound adjustment give you the control and responsiveness to explore at speed.
The RockShox Sektor is a perfect example of trickle down technology. Take the great performance and the chassis of the Revelation and tag it with a price you won’t believe. And there is still Motion Control damping and the new Dual Position Coil in the Sektor to transform your downhill into smooth and your uphill into easy.
Rock Shox Trail Suspension Fork Specifications:
Travel: 140mm, 150mm
Weight: 1837g
Damping: Motion Control
Spring: Dual Position Coil
Rebound: External Adjust
Steerer: 1-1/8" steel
Crown: Forged Hollow 6061 T-6 Aluminum
Upper Tubes: 32mm, Straight Wall Aluminum, Low Friction Anodized
Lowers: Magnesium, Post Disc Mount, 20mm Maxle Lite
Maximum Rotor Size: 210mm
