I've recently purchased a new shed, not from b and q, but a decent one with heavy duty framing and 21mm loglap pannelling. However the hinges are just screwed to the door. So if Mr/Mrs Thief arrives all they need to do is unscrew the hinges and the door falls off, even if it's locked at the other side!!
Surely shed manufacturers should be realising this? I've now removed the screws and replaced them with bolts, but shoulddn't this be done at manufacture?
Also what do people use to secure their bikes within sheds? Unfortunately I can't have a ground anchor, has anybody used
http://www.torc-anchors.com/shed-shackle.php
And since the anchor is only as good as the chain that's within it, have you got any recommendations for chains? The last one I nbought was £20 from halfords, are there an good quality ones I should be looking at?
I've got a £100 worth of padlock on the door!!
Thanks
Matthew
