I’ve had an issue with my seatpost slipping for a while now. It’s a KCNC SC Pro Lite post in a Kinesis XC Pro 3 frame. The fit is very tight – I have to use force to get it in and out, so it’s not as though it’s too loose. I imagine that when I go over a bump and my ghetto booty hits back onto the saddle hard enough, it is forced down. I’m not exactly a fat b’stard, 83kg, so it probably shouldn’t be happening.
I was using a light KCNC seatclamp, which has been replaced with a slightly heavier duty no-brander, but the problem persists. Is there any way to remedy the situation?
