Viewing 7 posts - 1 through 7 (of 7 total)
  • Seatpost shims – 30.9 to 31.6?
  • Rickos
    Can you get a shim that does 30.9 to 31.6 or do they only come in 27.2 or less as the start point? I’m liking the look of the Specialized Commander uppy downy post but they’re only doing it in 30.9 to suit their bikes.
    Teapot
    Doubtful, I was told by a manufacturer that shims need to be at least 1mm thick.
    racing_ralph
    could you get one made up rick?
    druidh
    You could buy a seatpost which is available in a more suitable size.
    2unfit2ride
    Coke can shim?
    Junkyard
    easily improvisable as such a small amount – if you have a cut at the back of the seat post insertion tube then it will probably clamp up the extra bit to. Second coke can , inner tube type shim – if you are using a commander should be fine and easy to do as no need to adjust once set
    Speedball comes in both sizes BTW
    Did not think it was avilable seperately in the UK though.
    Speshpaul
    You seen a price on a command post?
The topic ‘Seatpost shims – 30.9 to 31.6?’ is closed to new replies.
