I use one with one and han no issue.
The adaptors fit without removing anything. The hope outer black plasric disc needs to be in place as the thickness is allowed for in the spacing of the adaptor peoples mistake is thinking the adaptor should rotate inside the black dust shield when the guard should rotate with the BB axle in a normal x type set up there would be side loading against these discs so the would rotate as well (one of the benefits of a gxp setup is no side loading on the bearings which they are not designed to deal with so less wear).
Pop the shields out clean make sure the bearings are all the way home in the cups, clean and grease the groves in the cups that the shields sit in then pop them back in, they will then rotate with minimal drag. Press the adaptor in making sure you don’t unseat the bearing from the cup. I used a g clamp and some suitable sized sockets.
I have none over 1000 miles on mine now and it has been faultless and after trying loads of crank bb setups I am now sold on gxp
