What I did recently was …..
Stick tyre on, inflate dry with CO2 just to prove to myself the bead seats, then just to make sure it’s holding I stuck a track pump on it for a bit …. it’ll still leak air cos tyre is porous but used that to keep it ‘in shape’ for a bit.
But once you know that works you can either just stick the sealant in, then CO2 it to inflate (make sure valve is at top of wheel (i.e. furthet away from sealant) if you do this as the CO2 can make some of the sealant go ‘off’ and rubbery.
OR try this ….
I did this and it worked fine … I wiped both sides of the tyre at the bead with sealant. Then I CO2’d it, but no worries with sealant going off cos there’s hardly any in.
Then let it deflate naturally as the tyre walls are porous, but the bead will now be ‘stuck’. Either remove core and stick sealant in if you’ve got one of the sealant atachment things, or detach a small bit of tyre and pour it in, and cos the bead it ‘stuck’ now, it will just inflate with a track pump.
Never had uch luck with multiple tyre makes, wheels, when using soapy water.
