Depends what you’re after. Makes a great rear tyre when combined with some aggressive up front like a Magic Mary.
Rolls well, similar to a Racing Ralf but takes a bit of confidence to get the grip out of it as it needs to be lent over quite hard. Can be quite interesting braking in a straight line on steep loose stuff but if youre happy get it lent over and off the brakes it’s loads of fun!
If you’re used to running a semi slick on the back it’s a great tyre, if you’re not then a Hans Danpf might be a bit more forgiving. Can’t see it being much use on the front.
