bigyinn – Member
No no no no no!
That won’t work. Take the pads out and do it properly, by eye! If one piston moves slightly more than the other (and it will) your caliper will not be aligned correctly.
POSTED 2 DAYS AGO # REPORT-POST
Well it works for me, I do this probably every couple of weeks after i have checked my pads, i am using hope tech m4’s, never had any concerns on the performance of my brakes over the last 18 months.
Now lets look at this scientifically, when you apply your brakes the lever operates a piston forcing the hydraulic medium through the hose to the pressure side of the piston, prior to this happening there may be misalignment of the pistons, however as the pistons under pressure act against the pads and therefore the disc the pressure on either side of the calliper oil gallery will equalise, if the centre line of the disc is aligned with the centre line of the calliper the the pads will act evenly upon the disc, exerting equal pressure on the disc itself
