Just looking at the map and noticed that the path I suggested is not on the map 😳
The path leads from Milden Lodge and is obviously the one that goes up to below Wester Cairn… then across to Battock Summit (the most westerly Corbet)… where you can pick up the obvious and fun path down and across to Clochnaben (again it’s not on the map but it is very much on the ground).
Two options from here to get to Stonehaven – neither of which is anything like direct! South to Drumtochty Glen and then through the forest, or North and over Cairn Kerloch and again through the forest. Fetteresso/Durris forest is huge and sprawling, and far from flat. Pretty much all the maps are confusing as hell and it is easy to get lost or at best confused on the rather boring forest access roads.
Easiest route would be to go round Kerloch on the road and then through the forest – I can easy draw this route on a map for you – not a lot of road involved… adding in Kerloch summit would be stinker… but is a fun descent.
Whats your route? Which direstion are hitting Mount Keen from?
