Given the difference metal studs on running shoes make to traction on wood I’d imagine
these would be fairly good.
Possibly they would but can you imagine what would happen when you hit the rock garden straight after the roots? 😉
I am totally open to my technique being at fault. More than likely that is the issue. I try to hit roots straight on and not give the tyre chance to slide but I have no idea if that is right. have you got some pointers???
That is always the best way to hit roots. In addition you should be ‘unweighting’ your bike as you go over them too, or even better jumping over them completely by using one of the roots as a mini kicker.
