How do the Rock Razor and Minion SS compare to the Ardent Race in terms of braking and cornering performance?
I don’t know about the Minion SS, but I’ve used the Rock Razor and the Ardent Race – both as rear tyres on a 26″ hardtail – and my take is that the RR is slightly quicker in a straight line, corners better when it’s cranked over thanks to the big side knobs and brakes, erm, okay except when things get properly steep when it’s a bit slidey. Generally I can’t believe how grippy it is. The AR feels kind of more balanced all round, if that makes sense, just gets on with doing everything pretty well.
One thing that you need to bear in mind is that the RR comes as 2.35″ only – in 26″ anyway – and is a pretty big tyre with lots of volume, while the Ardent Race is only 2.2″ and relatively slim. It’s quite a big difference. I’ve used the 2.35″ Ikon as well and that’s pretty decent and quick, but has less cornering grip than the RR and gets very squirrely in softer conditions.
I prefer the Maxxis rubber compound on rocky stuff mind.
