Viewing 10 posts - 81 through 90 (of 90 total)
  • Schraeder to Prestatyn rim covertor?
  • HokeyCokey
    You might as well get two, then if one breaks you can always Bora Da other one.
    twoniner
    Brilliant thread, in tears laughing! 😆
    ononeorange
    If it doesn’t inflate, check that you aberaeron.
    It can easily happen if you’re Ruthin about.
    Get it lined up straight though. Sometimes it can just be the angle, see?
    Ambrose
    Denbeigh certain that it’s all done up tight.
    mrelectric
    Go by Cardiff it leaks.
    scaredypants
    rim covertor is quite a rarebit* isn’t it ? Highly desirable though
    (*yes, I’m sure we have but INRAT again)
    Ambrose
    Or Cadair Idris isn’t good enough.
    andrewh
    OP, aberdare I ask how you got on? Was the idea a gower?
    andrewh
    If you Hafen yet fixed it Cwm Rhonda my place and I’ll help you fix it, us welsh pool our resources. I Gwent to the LBS this morning after Brechfa. They had Bettws New-Ports which should Resolven your problem. They were expensive but look robust, should last for Ebbw. Vale for money in my opinion. Happy place my LBS, always lots of Merthyr.
    As an aside in discussions about Wales should we refer to LLLLLLLLBSs?
    Dales_rider
    Dont use an adapter in a bigger hole without Ruthin it up first, or you’ll make a Pyg of it.
The topic ‘Schraeder to Prestatyn rim covertor?’ is closed to new replies.
