So far the conclusion is just brake pad overheating.
The lever went to the bar only once – after the power loss and with a lot of force from my squeeze. As said it also did so after ‘feeling’ like it had overcome some resistance to do so.
Need to look at a parts diagram to understand if a plunger / lever can be overcome or moved aside (without damage) from excessive squeezing on the lever, as this is what it felt like.
The fact they worked again almost straight away once cool suggests nothing is broken so it’s quite intriguing.
