- This topic has 140 replies, 39 voices, and was last updated 8 years ago by josruu.
Saracen Ariel 15x linkage play AGAIN
LoCoFree Member
Had a look at the neighbors bikes, the play was due to bolt/bush mismatch, have been replaced and no play in the linkage for 3 weeks or so now, they ride a lot too.
Did notice one of the bikes has now developed play in the main pivot though.erniesbotFree MemberReally fancy one of these bikes looks ideal, but reading about this issue online has put me off! Surely there must be some happy owners out there?
I spoke to Madison and they say the issue has been resolved on the 2015 bikes.
Can anyone confirm if this is true?
bullroarFree MemberDid they say what the issue is or was?
My 14X is in the dealer workstand for the second time. Apparently the bushing was fine the problem is with a slightly undersized bolt, Madison are sending a correct sized bolt to the LBS for fitting.
LoCoFree MemberBolt/bush size mismatch, the shoulder of the bush on top link appeared to be a bit off too.
The bikes are 2014 models.adam_hFree MemberMy 2015 15x frame is on its way back from Freeborn after being with Madison, new bushes and bolts apparently. Will get it built up again next week and see how it goes.
RscottFree MemberMine too Adam, having said that I was told they had only heard of the issue once or twice before. They’ve now had the frame more than half of the time I’ve owned it
TroutWrestlerFree MemberI have been offered a 14x as a warranty replacement for a snapped then bent Grapil. Reading the above, I’m a bit nervous.
deviantFree MemberI had the 14X, it was fine. I thought the flexy rear ends were on the carbon models and I didn’t think the 140mm version came in carbon, mine was full aluminium.
callumrFree MemberI contacted Madison about the play developing in my 2014 15x frame, I was told there is a tolerance issue with the tan coloured norglide bushings that were fitted in those frames. They said they will be sending the new bushings to my local bike shop but due to warranty issues they can only be fitted by a mechanic at a Madison dealership. Madison do not cover the cost of fitting the bushings – I am not pleased with this as under the Sale of Goods Act 1979 goods must be as described, of satisfactory quality and fit for purpose and Madison have stated that the original bushings are not fit for purpose and in my opinion they should cover the post of fitting the correct bushings.
RscottFree MemberAriel 14x back from madison with new black bushings, play again after 10km, there now replacing frame but i can only imagine the replacment is going to need the original tan bushings changed imediatly
ivorhogseyeFree MemberHow do you get hold of them, do you go via your LBS? I’m trying to get some advice on which parts I need to replace but they don’t respond to the “contact us” page. I’ve just replaced the torx bolts and bushings at the top of the linkage (£35). That’s stopped those bits coming undone all the time. However there’s still loads of play, it looks like it’s at the middle axle. I’m wondering if I just need a linkage axle and washer or yet more bushings or even a new main axle. I don’t really want to be forking out yet more cash for stuff I don’t need.
RscottFree MemberI’ve been going through joe at freeborn was i bought it from them, he has been incredible, massive thumbs up to him, but the paper work shows hes sending it to sportline which is a seprate side of madison.
http://www.sportline.co.uk/tomhughes46Full MemberIntrigued by these black bushes. Would like to here more experiences with a 15x…
On mine both the axles on the linkage seem the same diameter. I’m wondering if because they are split bushes it’s actually the linkage bore itself is not compressing them to the right diameter? Currently mine seems ok but next time I have it apart (probably after the next ride!) I’ll get the vernier out.
To the person above considering one, maybe this year’s are better, but sadly I can’t recommend it based on my experiences.
adam_hFree MemberI’ve been going through joe at freeborn was i bought it from them, he has been incredible, massive thumbs up to him
+1 on this. Freeborn has become my go to shop when ordering online now.
eshershoreFree Membergood to hear Freeborn are sorting problems out for customer. Joe is a good guy with a lot of experience with full suspension frames
pinguFree MemberInteresting, I’ve replaced the bushings on my 15X once since I’ve had it – will see how long they last (was a 2nd hand frame). Dealt direct with Saracen – really good service, very impressed.
Muppet question time – The bushes on the tapered bolt with conical end were fine to swap out, but how do you take apart the single pivot that is on the machined allow linkage hidden behind the front of the rear triangle?
Cheers,
adam_hFree Member16x frame being returned for refund. Play in linkage again after a few rides. Joe at Freeborn excellent again, no hesitation and offered refund straight away without me even asking.
2015 15x frame ok after a couple of rides since coming back from Madison, but will be keeping a close eye on it.
RscottFree Member14x been back several times even had frame replaced and new bushings in it.The amount of time i have now spent trying to resolve this and without a bike i will never be buying a Saracen again and will activly avoid buying from freeborn. the customer service was excelent to start but they soon got bored and fed up which made me get arsey plus long time to respond to emails/phone calls and turn around times were never the 2 weeks max i was told.
robhughesFree MemberJust to bump this.
What’s the consensus on buying one of these frames.Has anyone got a good one or are all the linkages floored.
Thinking about buying a 2014 16x frame.
Loco your personal opinion please. 😉psycorpFree MemberHad my 2014 16x getting on for 3 months now. Bought it new. All seems ok so far. Only clunk I’m getting is topout from my Lyriks. Must strip them down……
psycorpFree MemberTook my 16x out of the shed today and felt the dreaded clunk from the rear. I just checked and I placed the order on 5th May so the bushings have lasted squarely 2 months.
Sad times.
Just had a bit of an investigation and it seems the play is around the bolt in the middle of the large cast linkage part.
I knew some 15x’s had issues with the bushings before I bought it so can’t complain really. I will, however, keep this updated with my experiences with Saracen/Rush Cycles warranty and customer service.
adam_hFree Memberrobhughes
Just to bump this.
What’s the consensus on buying one of these frames.Has anyone got a good one or are all the linkages floored.I wouldn’t bother buying one, not after building and stripping down 3 frames to return them under warranty within 4 weeks. First 2014 16x was knocking out of the box, replacement frame lasted 2 rides. My 2015 15x has been good so far after having the replacement bushes fitted but I’ve only managed to ride about 50 miles since, so still early days.
It sounds like it’s the same point on the linkage on all of them psycorp, that’s where ours went too.
Shame they have this problem as they ride brilliantly, I really enjoy the 15x and just hope it holds out on the new bushes. Bro spent his 16x refund on a 2nd hand Orange Alpine frame.
psycorpFree MemberI wouldn’t bother buying one, not after building and stripping down 3 frames to return them under warranty within 4 weeks. First 2014 16x was knocking out of the box, replacement frame lasted 2 rides. My 2015 15x has been good so far after having the replacement bushes fitted but I’ve only managed to ride about 50 miles since, so still early days.
Agreed, I really like the way mine rides too. Hopefully they have had the time to find out what the problem is and sort it, so it’ll only have to go back once. Having to send it back three times is above and beyond.
toppers3933Free Memberthe problem has been that nor glide changed the spec of the bush and didn’t bother to tell saracen that they’d done it. I’m told that the new bushes are in final testing and will shipping shortly.
psycorpFree Memberthe problem has been that nor glide changed the spec of the bush and didn’t bother to tell saracen that they’d done it. I’m told that the new bushes are in final testing and will shipping shortly.
Well that’s good news for me at least. Do you know if they insist that frames have to be shipped back or are they willing to ship out the bushes for customers to fit themselves?
bullroarFree MemberMy 14X is just back from having a fourth set of bushes in less than a year. Saracen have refused to replace the frame. Saracen have told LBS that a long term solution is close which I have heard before so won’t get excited by that. Saracen also won’t pay for LBS to fit new bushes, so you are reliant on goodwill.
I mailed Saracen last Monday asking for an explanation and pointed them at this discussion. I have not had a reply.
psycorpFree MemberAnybody know what the specs for the bushes should be???
Might be easier and quicker just to replace them myself by the sounds of it.
RscottFree MemberI wouldn’t rely on anything saracen or mansion said and I’d avoid the frame after severalnsets of bushings and a frame replacment in the space of 2 months I managed to get a refund from freeborn. I asked them to forward my complaint to saracen/mansion before this, it took quite some time for madison to reply making me certain promises to which I’m still waiting 3 weeks on for them to fulfill. Terrible service terrible design and appoling turn around time. Avoid if you value your time.
psycorpFree MemberWell Rush Cycles were straight back to me today. They admitted there was an issue with the bushings and that long term replacements were currently in testing and would be available in 8-10 weeks. In the meantime they’ll send out a set of the current bushes to tide me over.
Happy with that, good service so far.
bullroarFree MemberPity Saracen can’t be bothered to send me an email saying they are testing a fix. Their silence is damaging.
robhughesFree MemberIv’e just bought a 16 x frame.joe at freeborn has clarified that there checking the frames before they go out.If the old bushings are present then there will be a short delay while madison send out the newer ones and they’ll fit them before shipping.
I’m taking a chance i know…. 8)plinds71Free MemberI got a refund – euans2 mentioned me in the first page. I’ve asked about this on Singletrack before but I don’t think many people had picked up on it yet…
The tan bushes on my 2014 bike were replaced a few times, I was getting three weeks or so per set. Then, a bit out of the blue, new black bushes were available that would cure the problem – they didn’t last any longer.
Then I got a new 2015 frame – the thinking was that maybe the worn tan bushes had worn the frame. The new frame was built up on December 6th, it had play within the first week of January. Madison were no bother and the shop I bought it from gave me a full refund.
Mates have 26ers running these bushes and they’re ok. The Madison/Sportline’s warranty guy is a top bloke and I would happily buy another Saracen bike based on how well he dealt with my problems. The freehub failed too – knackered a weekend away – but I had a new one on my desk at work the day after I rang him. I had already bought Hope/Stans wheels, but I was impressed with that.
I bought a Process 153DL instead, very similar geo. Fitted the Hope/Stans wheels and swapped the SRAM parts for mud-friendly Shimano 1×10. Should have bought that in the first place…
mikeywxmFree MemberThat’s my 4th set now gone. Another 100 – 130 miles before it went. Spoke with LBS and he’s going to call me back tomorrow, once he’s spoke with sportsline/Madison. He’s been told the new bushings are a month away from being available. After the last fit I thought it was all sorted. I’m thinking of pushing for a replacement frame.
psycorpFree MemberQuick question for those who have replaced the bushings on their frames. The large bolt in the middle of the large CNC machined linkage part, is it a standard thread or an opposite thread like the small Torx bolts at the top of the linkage????????
I’m asking as the bolt on mine seems to be VERY tight and before I give it some real welly I want to be sure which thread direction it is.
Cheers.
Oh I should say thanks to Colin at Rush Cycles for getting the replacement bushes out quickly to me too.
RscottFree MemberIt seems that the suppliers are doing there up most to keep customers happy (to an extent) But the issue lies at saracen and madison who refuse/dont/lie when they do or don’t reply. I’m still waiting for a reply email that i was prommised now 4 weeks ago.i was promised this on the phone direct from the person who was dealing with my issue.
It seems madison/saracen just don’t care and will say anything to get people off there back.
tomhughes46Full MemberPsycorp: The only tricky one is the one where you need to pop out the taper shim and then wind it out from the other side. The rest just unscrew as you would expect. Likely to be threadlocked though, and the original instructions suggest loosening all the other bolts first.
Edit: Mine is a 2015 151, and has no Torx bolts so this may be useless advice.
psycorpFree MemberAhh ok. Thanks anyway Tom.
For clarity mine is a 2014 16x so if anyone can confirm the thread direction of the bolt in the pic below that would be great.
bullroarFree MemberBe careful with that bolt, the head seems soft and easily rouned. LBS have trashed two during my multiple replacements.
Saracen called me today to apologise for being slow to respond and to explain the situation with respect to a fix. Summary is they are in final testing of the fix, testing on real bikes using uplift in the Alps apparently. Should have bits ready to send out in a few weeks. In the meantime they are happy to keep sending out replacement bushes.
I did suggest an official public statement/explanation might be a good idea given the damage this has caused to the brand. I won’t hold my breathe for that one.
psycorpFree MemberHi bullroar
Do you know if it’s a standard “lefty loosy, righty tighty” thread on the bolt?
Given what you’ve said I don’t want to put any real torque into it without knowing.
bullroarFree MemberMine is mormal (14x), 6mm hex on non-drive side of bike. Make sure the tool is well seated which is not that easy given the access to the hole.
The topic ‘Saracen Ariel 15x linkage play AGAIN’ is closed to new replies.
