Hi Guys,
My friend has bought a 2012 Santa Cruz heckler second hand. After a couple of rides the crankset came off.
When I looked at it I found that it has an SLX Chainset, with a hope bb. There is also an MRP seatube mounted top guide and a bb mounted blackspire stinger.
Being a 73mm shell I know that you should run one spacer on the bb but I assumed that the stinger was acting as said spacer. However after looking at it, it seems that it is too wide as not enough axle is protruding through. With it all together the plastic clip on the non-drive side crank would not engage in the axle either.
I removed the stinger as a temporary measure and it sits together perfectly, albeit catching the top guide in the lower gears.
Has anyone else experienced this and what is the best solution please?
Regards
Tom
