Viewing 9 posts - 41 through 49 (of 49 total)
  • Santa Cruz Grease Gun alternative…
  • Pawsy_Bear
    Yup give the axle and bearings a bit of TLC clean and grease.
    jsync
    I have that gun and use stalube marine grease cartridges
    gaberin
    oscillatewildly
    Just tried again with sc grease gun and failed again!!
    Cleaned and prepped all the pivots and link itself, free of debris and crap
    Tried to regrease with the link out and the pivots pushed through and grease still splurged around the nipple and nowhere else
    Then put back in and tried again and exactly the same again!
    So im gonna order a hilka now and get some cartridges can only assume its the crap sc gun
    Also though is there a manual way of regreasing the bearings? If i jusr take the link out, take the caps off each bearing and the seal and just put grease in by hand is this essentially thw same thing the gun does? Or does the gun get deeper inside in each bearing or similar? Its an easy job for me take the pivots out and do it that way if it does the same thing!
    Any thoughts?
    frogstomp
    Has anyone tried the Hilka with bulk grease – i.e. no cartridge, direct filling the cavity (ooer)?
    I tried and it pushes past the plunger and oozes out of the plunger end. Am I doing something wrong, or have I misinterpreted the ‘bulk loading’ bit?
    Pawsy_Bear
    don’t force the plunger just let the spring reassert itself, sounds like you might have broken the rubber seal?
    its a lot easier with the cartridges 😀
    If you have problems getting the greese into the bearings let the air out the can that helps a lot
    trail_rat
    I reload the old cartridge.
    thered
    Bookmarked
The topic ‘Santa Cruz Grease Gun alternative…’ is closed to new replies.
