Am I being unreasonable?
I got a carbon nomad at the end of April. I decided to replace the grease in the pivots using the grease ports and the supplied grease gun. I watched the video on the internet. Went to do it on the lower link. First one fine. Second one, the port came out the frame and stuck in the grease gun.
Took back to my LBS (top guys there) and they got a replacement port, but that wouldn’t go back in the frame properly as I guess the hole it goes in to in the lower link is now damaged.
Quick search of the internet has suggested I’m not the first person to suffer this and in the 2012 model I notice they changed the design from push fit to screw fit grease ports which as a minimum suggests a compromised original design.
So imagine my surprise when the LBS phones Jungle only to be told that I can’t have checked the instructional video on the internet (first thing I did) and this is a common user error issue. Based on this I would have to buy a new lower link.
F****** EXCUSE ME?????!!! I SPEND 2.5k ON A NEW F****** FRAME, CARRY OUT A SUPPOSEDLY F****** STANDARD MAINTENANCE ROUTINE USING A PIECE OF EQUIPMENT THAT THEY F****** SUPPLY WITH THE F****** BIKE THAT IN TURN ****’S IT AND THAT’S MY FAULT? HOW EXACTLY?
Anyone else had a problem with Jungle and anyone got a suggestion on how to deal with them?
Did you notice I managed that whole rant without using the word nipple once?
