I’m tempted to get a base model Lumie but at 60 quid it’s a fair bit for something that might not make me feel less of a miserable twunt in the morning.
My flatmate used to use one and I think it worked for him. Of course, depending on the curtaining in your room, it may only be useful in winter, but if it helps, it’s all good.
Failing that, how about a coffee percolator on a timer? Set it to start 5 minutes before you get up…
Full on, no gradual wake up. Bit bright for the first few minutes but really works. Lumie was pretty ineffective.
If you really want it, I’ll go and dig it out the spare room and sell it. It’s the original digital model with the curved glass cover. But I’d say just buy a light box and a 1.99 timer plug from Tesco.
I use a lumie the £99 one. I get up at 5 everyday and since I had the lumie I find my enthusiasm on waking is instant, I used to think I was going to die I felt so bad when woken by alarm clock noise. The gradual waking rocks, also White noise to get to sleep rocks.
In my opinion they work well
If your lumie was not bright enough buy a brighter bulb?
If you have time to dig it out I would be interested. If I feel a benefit, I will have a look into the light box and hand over the alarm clock to my brother who is also afflicted with being a miserable twunt in the morning.
The Philips one I have isn’t really for SAD – it’s just for wake-up
It’s actually the second Philips one I’ve had. The original one had all the quality of a paper hat. The volume control broke and the sound quality was awful. It had a really “cheap” feel about it and the newer one is a lot better in all areas (particularly the sound) – though still has some design flaws, and they even do an Ipod version now.
I do think they work, I always feel better waking up when I’m using it and more rested. The only downside is that the light starts about 20 mins before the alarm so on occasion you can get an even earlier start.
You can often find them at 50% off – I got this one from Boots.
I don’t think the ‘D’ is depression in the sense most people think of it, more the feeling of lethargy/inability to get moving/going – my wife uses a lightbox and finds it helps in getting up in the morning and she at least feels better for it (though it could perfectly easily be a placebo though that said, I find I feel wide awake when sat next to it for a while).
You can get lights for SAD – which I have no experience of. These are just alarm clocks that wake you up a bit more gently – into “simulated daylight” rather than the pitch darkness.
