A quick lesson in maintenance.
Remove the chain (get a powerlink or something) before washing then spray with gt85 to get rid of the water, if gt85 gets on your disc pads they are history. Once the gt85 has evaporated refit and lightly oil.
Powerwashing will help kill your bike, the pressure is so high it will wash all the protective/lubricting grease out of your hubs, headset and bb cups.
Don’t use normal grease with your seatpost – get a proper seatpost one, otherwise your seatpost will constantly sink.
If like me you are lazy, leave the bike to dry, brush off the mud once dry and relube the chain with proper lube – you should get away with it quite well if you are keeping the bike in your house.
I wouldn’t worry about the seatpost split – all my steel bikes have one and it’s not a worry. take the post out to allow the sitting water to evaporate out if you want.
