Issues ? Yep riding round chainrings after…
That’s honestly the only issue ….
I did briefly put a non oval 1×10 on my trail bike (2015 Whyte t-130) with a 73mm GXP BB onto the 96 bcd outer bolts …
I stuck on my wheel from my XC (though the wheels is a trail rim) that has an absolute black 40T expander on a 13-36 (no 12T and absolute lock ring).. identical m780 rear mechs and brand new chain (Kmc as on other)
I’m lost as to why it won’t work ! (I’ve done this more than a few times) The brand new chain (cleaned of packing gunk and then lightly oiled) keeps slipping in 1st but only under load (1:3) . I added 2 extra links…(just to check) played with the b-tension … wound it back on upper limit … bunged some extra tension on cable … don’t know if it’s the chain line or is it the new chain … the expander doesn’t look worn… I’ve had 5mm clearance and with the b screw all in even tried 10mm
Went round in circles and …. erm accepted defeat and decided to stick m8000 instead (I’ve been collecting everything for a while and finally got the shifter today by royal snail post…. anyway … that works in the bike stand ….
I’m changing BB this weekend to Hollowtech so I can use my 170mm m785 cranks with absolute oval on. But I’d still like to know why….
