STATO – I wasn’t sure just how it would work. Can you run small front/large rear – a required combination – and have tyre clearance?
Not sure on specific bike combos but based on the fact you can buy a Jones Plus complete with a boost crank and (seemingly*) normal rear hub it must work.
*no indication its boost rear hub
EDIT
From the Jones manual..
For instance, a Shimano Boost crankset for mountain double (denoted by the addition of B2 to the part number) moves the position of the inner chainring out to 45.8mm from the centerline, which gives clearance for lowervolume 29×3” tires such as the Vittoria Bomboloni and Maxxis Chronicle, but not larger volume ones such as the Bontrager Chupacabra. Because this introduces a gray area where some tires fit and some don’t, we only recommend using the Surly O.D. cranks on Jones Plus frames.
