I’ve got this exact fork on my BLT2, replacing the original Pike 454 U-Turns. I reckon the Rev is noticably better in handling both small and big bumps, is lighter and I reckon stiffer. The dual position also works brilliantly – I don’t use it much but very effective when I do
I weigh about 85kg with all kit including 3l of water. Initial set up for 20-25% static sag was 140psi which I found was too low as I was blowing through he travel, so now running it at 150psi which seems about right. I run the rebound just on the fast side of the mid point or it tends to pack down. Compression damping is 3 clicks from clockwise and floodgate about 2/3 round. Hope that makes sense
Seems the perfect fork for everything now, from fast fireroad descents to very steep and technical rock sections
