The rebound is realllllllyyyyyy slow.
Not like 1″/second slow, but slower than I’d set it. The adjuster works fine but the range seems biased to the slow end, so despite setting them up for my weight (i.e. quite a lot of air) they still don’t rebound as quick as I think they should, I definately noticed it when coming down jump gulley at Swinely, over-shot the last double which wouldn’t normally be a problem but the fork was still compressed heading into the berm that kicks you out at the end, needed fresh shorts after that!
Took the lowers off today and there was oil in there, so I just wiped them down, smeared some Rock and Roll superslick under the seals and added some 15wt suspension fluid to the lowers. Marginal improvement but not enough to cure it.
Are they all like this out the box and it’ll bed in, or do mine have an issue?
Sektor SL RL (solo air, rebound and compression adjustment, motion control damper).
