Careful now…
There are a few versions, the good ones have the old Motion Control Damper in them, which was that damper in the old Pikes and Revelations. Perfectly good damper and fork if a little twangy over 120mm travel by current standards.
I would avoid the cheaper versions you might find with the Turnkey dampers as those dampers are frankly horrid.
If you can find a deal I’d go for a set of Yaris personally.
I have used Old Pikes, New Pikes, Old-ish Revs, New Revs…
The chassis stiffness of the Yari (same as New Pike) and it’s Motion Control Damper is brilliant budget combo.
