My Pikes have started clunking or ‘topping out’ when I try and lift the front wheel – i.e. manual / wheelie etc.
They weren’t doing this a few weeks back. They are 454 dual air 110-140 travel adjust jobbies if this matters?
They’re getting on a bit – stanchions are scored but not losing any oil apparently.
I checked the air pressure and they are set to the PSI I always use.
I just want to nurse them through the winter before thinking about a new set. What can I do? Oil change? Anything else? Is there a guide somewhere for removing stanchions and adding oil like for Fox forks?
TIA
