the rp23 on my hemlock lacks mid travel support and blows through the travel, find through the rough stuff but jumps and drops it bottoms out, i can nearly bottom it out. i run 180 psi, and the smaller volume reducer, mojo said i cant use a bigger spacer as the pressure will be to high? i already have it pushed. looking into some options, push big hit kit seems to be for extreme applications, my application isn’t extreme just normal trail riding, also looked at vorsprung corset which seems to add small bump sensitivity, mid range support and ramp up at end of travel which is what im after, any one hav experience with either
