Following some emergency brake pad swapping around (damn you, royal mail!) before yesterdays trip to the Quantocks, I find myself with a troublesome problem.
The spacing has always been tight on my combination of wheel\forks\brakes, but the new pads are slightly thicker, and adjusting the caliper to clear the rotor means that a a couple of the spokes just touch the caliper on occasion.
I’ve found +1mm Hope 6 bolts spacers online, but I don’t want to push the problem the ‘other’ way and either foul the rotor with the forks or run our of adjustment at the caliper.
Has anyone used any other spacers for this job? I’ve found reference to a Syntace shim pack of 8 0.2mm shims, but I can’t find UK stock, so it’s a long wait or expensive postage.
Would anyone have a spare 0.2mm (maybe a couple?) of shims they’d swap for gratitude and\or a beer? Maybe a +1mm Hope I could try, see how things go?
