- This topic has 71 replies, 22 voices, and was last updated 13 years ago by Dickyboy.
Rotating weight and climbing
crikeyFree Member
I'm not trying to disprove anything. I agree with the theory. I'm saying that in the real world, and specifically the real world of leisure cycling as practiced by me and you, that the benefit of reducing rotating weight as opposed to any other weight is overstated.
In addition, the reduction in weight as practised by me and you in the context of mountain biking and often asked about on here, has a negligble effect on our performance.
I do agree that psychological factors associated with perceived performance benefits are important.rsFree MemberI said there will be force to lift the bike against gravity, and yes, this will be greater for heavier wheels due to their mass, however, the extra rotational inertia of the wheels does not affect the force needed to lift them. If it did, a spinning wheel (or anything else) would have to be heavier than a non spinning thing, which is not the case.
This would be fine if you were just trying to lift the bike over a fence but your trying to propel it forward as well as up by making the wheels go round in circles.
TandemJeremyFree Memberrs – he is right – the rotation of the mass can be ignored unless it is accelerating. going uphill at a steady speed nothing is accelerating
simonfbarnesFree MemberThis would be fine if you were just trying to lift the bike over a fence but your trying to propel it forward as well as up by making the wheels go round in circles.
yes, but at constant speed, there is no acceleration, so inertia doesn't matter. It so happens that inertia and mass are directly proportional for non-rotating objects, and that rotational inertia is double that for objects where all the mass is concentrated at the same distance from the axis of rotation (like a wheel). When you lift something at constant speed, what matters is its mass, not its inertia.
simonfbarnesFree MemberI do agree that psychological factors associated with perceived performance benefits are important.
to which end it might be more useful to alter your beliefs creatively 🙂 For instance you could cultivate the belief that blue valve caps are faster.
simonfbarnesFree MemberRed bikes are faster – everyone knows that
I have a red rear hub and red nail varnish so I'm sorted 🙂
rsFree MemberPosted 13 years agocrikeyFree MemberAgreed, I'm quicker when I wear my new Raji gloves, and much quicker when I wear a cycling cap turned backwards instead of a helmet.
gcasterFree Memberrs – he is right – the rotation of the mass can be ignored unless it is accelerating. going uphill at a steady speed nothing is accelerating
Well kind of…
When you're going up hill gravity is constantly pulling you down and your wheels are constantly wanting to decelerate. In order to overcome this deceleration you provide the acceleration force with your legs (at a constant speed these forces are balanced).
Unfortunately for us the inertia of the wheels is a contributing factor to what we are pedalling against. Thus at constant speed the rotating mass still has an effect on how much effort we have to put in.EDIT: Also, if you think about it, the bike constantly accelerates and decelerates throught the pedal stroke. If yours doesn't you'll be given a new gold necklace in 2012.
gravitysucksFree MemberAlso, if you think about it, the bike constantly accelerates and decelerates throught the pedal stroke. If yours doesn't you'll be given a new gold necklace in 2012
Bingo. Out of the saddle on a big hill and roational inertia will make a difference.
Unless of cause your all roadies arguing the toss on a mountainbike forumTandemJeremyFree Memberrs – your first link doesn't work and the second is starting from rest – so acceleration plays a part it is not steady state and there is no distinction between the effects due to rotating mass and static mass on the speed.
crikeyFree MemberThus at constant speed the
rotatingmass still has an effect on how much effort we have to put in.Fixed that for you.
Yes, but these 'accelerations' are miniscule and are lessened by a heavier wheel….flywheel effect, remember?
crikeyFree MemberThe advantage of light bikes, and particularly light wheels, from a KE standpoint is that KE only comes into play when speed changes, and there are certainly two cases where lighter wheels should have an advantage: sprints, and corner jumps in a criterium.[13]
In a 250 m sprint from 36 to 47 km/h to (22 to 29 mph), a 90 kg bike/rider with 1.75 kg of rims/tires/spokes increases KE by 6,360 joules (6.4 kilocalories burned). Shaving 500 g from the rims/tires/spokes reduces this KE by 35 joules (1 kilocalorie = 1.163 watt-hour). The impact of this weight saving on speed or distance is rather difficult to calculate, and requires assumptions about rider power output and sprint distance. The Analytic Cycling web site allows this calculation, and gives a time/distance advantage of 0.16 s/188 cm for a sprinter who shaves 500 g off their wheels. If that weight went to make an aero wheel that was worth 0.03 mph (0.05 km/h) at 25 mph (40 km/h), the weight savings would be canceled by the aerodynamic advantage. For reference, the best aero bicycle wheels are worth about 0.4 mph (0.6 km/h) at 25, and so in this sprint would handily beat a set of wheels weighing 500 g less.
In a criterium race, a rider is often jumping out of every corner. If the rider has to brake entering each corner (no coasting to slow down), then the KE that is added in each jump is wasted as heat in braking. For a flat crit at 40 km/h, 1 km circuit, 4 corners per lap, 10 km/h speed loss at each corner, one hour duration, 80 kg rider/6.5 kg bike/1.75 kg rims/tires/spokes, there would be 160 corner jumps. This effort adds 387 kilocalories to the 1100 kilocalories required for the same ride at steady speed. Removing 500 g from the wheels, reduces the total body energy requirement by 4.4 kilocalories. If the extra 500 g in the wheels had resulted in a 0.3% reduction in aerodynamic drag factor (worth a 0.02 mph (0.03 km/h) speed increase at 25 mph), the caloric cost of the added weight effect would be canceled by the reduced work to overcome the wind.
Another place where light wheels are claimed to have great advantage is in climbing. Though one may hear expressions such as "these wheels were worth 1-2 mph", etc. The formula for power suggests that 1 lb saved is worth 0.06 mph (0.1 km/h) on a 7% grade, and even a 4 lb saving is worth only 0.25 mph (0.4 km/h) for a light rider. So, where is the big savings in wheel weight reduction coming from? One argument is that there is no such improvement; that it is "placebo effect". But it has been proposed that the speed variation with each pedal stroke when riding up a hill explains such an advantage. However the energy of speed variation is conserved; during the power phase of pedaling the bike speeds up slightly, which stores KE, and in the "dead spot" at the top of the pedal stroke the bike slows down, which recovers that KE. Thus increased rotating mass may slightly reduce speed variations, but it does not add energy requirement beyond that of the same non-rotating mass.
Lighter bikes are easier to get up hills, but the cost of "rotating mass" is only an issue during a rapid acceleration, and it is small even then.
Nicked from Wikipedia…
http://en.wikipedia.org/wiki/Bicycle_performancesimonfbarnesFree Memberand your wheels are constantly wanting to decelerate
confused thinking. Force is required to lift the wheels (and every other part of the bike and rider), and this is a static gravitational matter unrelated to inertia.
DickyboyFull MemberJust because calulated energy input might be say 1% greater or lesser doesn't necessarily equate to 1% faster or slower results, it won't be a linear scale, especially when performing at or close to your limits.
TandemJeremyFree MemberClassic STW threaad this one – nearly as good as Wobbly wheels for folk arguing black is white and totally getting the wrong end of the stick.
How come SFB and I are on the same side and right? Most unusual 🙂
brakesFree Membernot sure what everyone else has said, probably something about not accelerating when going at a steady speed.
friction is slowing your wheels down which you have to overcome by accelerating them, therefore you're always having to accelerate them unless those friction forces are overcome by gravity which they won't be if you're going uphill
that's what I reckonsimonfbarnesFree MemberHow come SFB and I are on the same side and right?
Newton sorted this out over 300 years ago, it's not exactly cutting edge 🙂
TandemJeremyFree Memberbakes – holding them at steady speed is not accelerating – Doh!
simonfbarnesFree Memberfriction is slowing your wheels down which you have to overcome by accelerating them, therefore you're always having to acclerate them unless those friction forces are overcome by gravity which they won't be if you're going uphill
uh, if you're going at constant speed then, by definition, there is no deceleration! Yes, you have to overcome friction and gravity, neither of which are related to rotational inertia.
oliverd1981Free MemberIf your are trying to climb a "rough" hill (and on a bike thatcan be pretty much anything that's not smooth tarmac you will naturally try to maintain a steady pace (especially with a group)as your wheel overcomes every little lump and bump you have to input a little more power to spin the wheel back up to speed (There will be some degree of flywheel effect but the losses, especially at low speed will be quite substantial) A lighter wheel will feel easier to pedal especially if you pushing quite hard, but I reckon it comes down to rolling resistance (friction) more than anything.
brakesFree Memberit's impossible to hold them at steady speed though, especially on a mountain bike
especially with all the bumps, rocks, cracks, roots constantly slowing you down, even in small amounts, they are constant and will add up
EDIT: what oliver saidby definition
definition means nothing
DickyboyFull Memberjust imagining the speed i could go if I was always accelerating 😆
TandemJeremyFree MemberBakes – but a heavy wheel with more rotational inertia will be less prone to slowing over bumps…………..
simonfbarnesFree Memberit's impossible to hold them at steady speed though, especially on a mountain bike
especially with all the bumps, rocks, cracks, roots constantly slowing you down, even in small amounts, they are constant and will add upno, they average out 🙂
rghly kdlbcp er wbcvbbe rtmq eppt! (definition-free language)
oliverd1981Free Memberjust imagining the speed i could go if I was always accelerating
That would be the same speed as you can go, spun out, in your fastest gear, or faster, if gravity assisted.
The corrected perspective is – imagine how fast I could go if I wasn't constantly being subjected to forces that cause deceleration.
poppaFree MemberWhen you're going up hill gravity is constantly pulling you down and your wheels are constantly wanting to decelerate.
Yeah, but if your wheels are heavy they will have more inertia and resist deceleration more than light wheels.
smiffyFull MemberOn the steady climb described there will not be a difference, but when it comes to interesting MTB stuff; slowing, speeding up, switchbacks, swoopiness, the agility of lighter wheels will become apparent.
simonfbarnesFree Memberthe agility of lighter wheels will become apparent.
or perhaps the skittishness ?
"just imagining the speed i could go if I was always accelerating"
it goes without saying that to be always accelerating you'd need some other source of motive power than pedalling, and I imagine avoiding obstacles will become harder as you approach the speed of light…
DickyboyFull Memberyes but as I approach the speed of light I would also become close to infinite mass & everything would have to get out of my way or get crushed in my path 😈
The topic ‘Rotating weight and climbing’ is closed to new replies.
