I have a pair of SID RLT Ti 120mm QR15 on a Turner Flux & after being very impressed I now have another pair set at 100mm on a hardtail.
On the Flux I have approx 90psi in both the negative & positive chambers which gives about 5% sag unloaded & about 25% loaded, & I’m about 90kg.
I tried the other pair for the first time last tonight set at 100mm on the hardtail. Initially I had to put 120psi in the positive to get 25% loaded sag, then when I tried the same pressure in the negative I ended up with 25% sag without even getting on the bike.
Time was running out for a ride so in the end I went with 130psi in the positive & about 90psi in the neg. The forks rode at about 30% sag loaded. The higher pressure was noticeable over 120mm pair on the Flux.
So, just wondered what everyone else was running & how have you got on with set-up?
From some feeb back from other users it seems I’m running low pressures on the 120mm pair for my weight compared to others.
