What is the wording on the fork (ie its full name?)
AFAIK it depends on whether it is the ‘trail/all mountain’ model or the ‘cross country version’
Also whether it is coil, coil U-turn or solo air
Trail/all mountain models are named 327, 335(turnkey lockout) and 351(motion control) or were until recently
All are available in coil U-turn 85-130mm (some 95-140mm models later (all if not most with 20mm thru-axle?) or solo air (which is internally adjustable from 80-130mm(130mm requiring no spacers in the spring), there may also be some 90?-140mm internally adjustable models?
XC models (XC, SL and race – I don’t know which is better than anbother) I believe have a maximum of 100mm. Some are fixed travel coil, some are solo air which may or may not be internally adjustable between 80-100mm?
I believe the sector/sektor has replaced the trail/all mountain recon now
