I knocked the lowers of my Rebas, cleaned them up and refitted with suspension oil and Red Rum a while back to clear out any bushing debris, but didn’t change the oil inside the legs (I have done this with Dukes before though).
The Reba service instructions basically talk you through a complete strip down and rebuild but I don’t feel that confident about dismantaling everything and faffing with the ‘O’ rings (when they go it’s probably a case of sending them off to TF Tuned for a proper job) but I make decide just to change the internal oil.
As the instructions are for a total strip down, the lowers are off when the internal oil is changed, I assume that I can simple remove the air pressure and open up the legs and change the oil with the lowers in place (the requirements for the damping/spring legs to be fully extended can presumably me met by pulling the lowers away from the crown). I’d be leaving the negative spring assembly in place.
I reckon it makes sense to ask though as I’m not sure how the postive and negative chambers relate.
