too many tokens will start to effect small bump, I tried two in my 160 26″ and it made it harsh, dropped back to one and loads better.
I am 85kg, but run my bars quite high so not a lot of weight over the front, 25% sag seated, 30% sag standing, I run 65psi, 3 clicks lsc and one token, rebound I think just a few clicks quicker than dead middle.
this was roughly how I set it up originally, rode it on trail centres and dh runs, played about with settings, adding another token, and quickly went back to the above.
the 29’ers come with tokens installed, are you using full travel? if not try to remove a token give it a go, can always bob it back in.
