Hi Guys,
I’m a long time loiterer first time poster as I’ve always managed to find an answer to my problem in the forums until yesterday.
I’m off the bike at the moment with a shoulder injury so decided to do a lower leg service on my pikes, something I’ve done on many forks over the years without a problem.
Whilst removing the lowers the fastener nut on the damper side was just spinning i.e. the damper rod was spinning with the bolt and not unthreading.
Tried everything from compressing the fork to pulling up on the fork with no joy.
I ended up using a dremel to cut the flange off the nut and then sand around the nut so the whole lot would fit through the hole in the lowers while still leaving the hex on top. Once the lowers were off I was then able to clamp onto the damper rod and unthread the bolt although it was very stiff to unthread especially the last few turns suggesting the threads have somehow become crossed.
The threads on what remains of the bolt are fine as it threads into the air side rod no problem so therefore the threads on the damper rod need chasing with a tap.
I have a new fastener kit ordered and plan to chase the threads with an M8x1.0 (if anybody knows any different please let me know.
My questions to you guys are;
is my planned repair likely to work or should I bite the bullet on a new damper rod (approx. £85)?
What would cause the original problem to occur?
Where does the resistance on the damper rod come from to allow you to torque the bolt up in the first place?
Sorry for the long winded thread, Hyena.
