Viewing 5 posts - 1 through 5 (of 5 total)
  • Rockshox Oneloc removal?
  • samcuk87
    As per title really. Has anyone removed one of these? The default position of the loc is locked out so its not as simple as just removing the lever and cable. I can’t find anything on Google. I’m pretty handy and have no problems taking the fork apart if needs be.
    Any help appreciated.
    benjii19
    No
    samcuk87
    Ben, go forth and multiply.
    qwerty
    I believe you can disconnect the spring, thus leaving it active as default, then replace the top cap. Google should have some video instructions.
    otsdr
    Might as well replace the compression assembly with one of these babies if you don’t need the lockout: http://www.novyparts.com/produits-novyparts-suspensions-vtt/splug-bloc-de-compression-hydraulique/
The topic ‘Rockshox Oneloc removal?’ is closed to new replies.
