Have one of these on my strive, the piggy back model which I’ve never been overly impressed with. The frame is known to blow through its travel heavily and this shock is supposed to be better than previous versions but I just can’t get it right.
I have to run nearly max air pressure and much less sag than normal to get it to sit up in its travel, even so I can only use the middle trail mode for descending, the full open just knocks and bottoms out under compression whatever I do with it. Even in middle mode I can knock the red ring off the bottom of the shock without much effort.
I know you can put the red reducer rings in which I think might help and get the debonair air sleeve which I don’t, but is it better to have it retuned? It’s currently LL which is low compression low rebound.
Would a medium or high setting cure it a bit? I’m 90kg in birthday suit so not the lightest of riders.
