• This topic has 6 replies, 5 voices, and was last updated 8 years ago by benz.
Viewing 7 posts - 1 through 7 (of 7 total)
  • Rockshox Judy XL. Triple crown. How to remove?
  • benz
    Neighbours lad has an older Patriot with said forks.
    I’ve given him some 140mm Pikes and front wheel to update his bike a bit.
    But….how do I remove the triple crown Judy’s…?
    Thanks.
    wysiwyg
    With an Allen key…
    orangeboy
    You may also find a rubber mallet useful to tap the top crown off
    benz
    Wysiwyg,
    Care to elaborate? I have obviously missed the subtle but in depth guidance you are hoping to impart so a simple hint may benefit simple and technically inept me.
    Thanks.
    sillyoldman
    Loosen the three pinch bolts on the upper crown (one on each stanchion, one on the steerer) in order to remove it. Usually needs persuasion with rubber mallet… After that it’s the same as removing any fork.
    Are they old straight steerer Pikes? Frame will only take straight steerers.
    survivor
    From the look of pics of them there is Allen bolts holding the top crown onto the legs and steerer so should be 3. These need slackening off, Stem and spacers off as well. If the crown doesn’t pull up it’ll need persuading with a soft blow hammer.
    edit. Beaten to it but at least we agree.
    benz
    Thanks. Bike not with me to do the swap, hence question for preparation purposes.
    Yes, some straight steerer Pushed Pikes.
    Short stem and wider bars for him too.
    He’s an energetic 11 year old, so biking helps him burn off his energy and he is mad keen which us great.
The topic ‘Rockshox Judy XL. Triple crown. How to remove?’ is closed to new replies.
