I’ve ordered myself a new airshaft to extend the travel on my Sids from 100 – 120mm. The forks themselves have hardly been used so the seals etc are fine.
All I thought I had to do was whip off the lowers, replace the shaft, fill up with oil (5 ml of 15 wt in each lower leg as per sram tech docs) and off I go.
Question is it also mentions 100ml of 5 wt in the upper leg. Do I need to bother messing about with that and s it required at the same time as doing the lowers?
I was planning to follow this video, which although for a pike seems very simple.
[video]https://www.youtube.com/watch?v=7WcCIFguChA[/video]
